Run Time: 0.000415
Run Time: 0.000161
WHERE (`xf_thread`.`thread_id` = '15390')
Run Time: 0.000560
WHERE (`xf_post`.`thread_id` = 15390) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002741
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (176966))
Run Time: 0.000980
Params: 15390
Run Time: 0.000074
Params: 0,
Run Time: 0.000110
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=15390, 1714973755, , 0,
Run Time: 0.000086
WHERE (`xf_session_activity`.`user_id` = 14162) AND (`xf_session_activity`.`unique_key` = '14162')
Run Time: 0.000145
WHERE (`xf_thread_reply_ban`.`thread_id` = 15390) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000173
Run Time: 0.000172
bytes_sent | 12311 |
bytes_received | 350900 |
packets_sent | 124 |
packets_received | 1085 |
protocol_overhead_in | 4340 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 278140 |
packets_sent_command | 61 |
packets_received_change_user | 105 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 87 |
rows_buffered_from_client_ps | 87 |
rows_skipped_ps | 87 |
proto_binary_fetched_bit | 318 |
proto_binary_fetched_short | 363 |
proto_binary_fetched_bigint | 954 |
proto_binary_fetched_json | 672 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 276045 |
