Run Time: 0.000514
Run Time: 0.000181
WHERE (`xf_thread`.`thread_id` = '27830')
Run Time: 0.000653
WHERE (`xf_post`.`thread_id` = 27830) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003998
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (397854, 398242, 398268, 398722))
Run Time: 0.000867
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 27830
Run Time: 0.000099
Params: 0, ځd
Run Time: 0.000140
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ځd, XF\Pub\Controller\Thread, Index, valid, thread_id=27830, 1715336579, , 0, ځd
Run Time: 0.000090
WHERE (`xf_session_activity`.`user_id` = 22693) AND (`xf_session_activity`.`unique_key` = '22693')
Run Time: 0.000164
WHERE (`xf_thread_reply_ban`.`thread_id` = 27830) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000227
Run Time: 0.000206
bytes_sent | 12365 |
bytes_received | 359018 |
packets_sent | 124 |
packets_received | 1087 |
protocol_overhead_in | 4348 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 286258 |
packets_sent_command | 61 |
packets_received_change_user | 107 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 89 |
rows_buffered_from_client_ps | 89 |
rows_skipped_ps | 89 |
proto_binary_fetched_bit | 495 |
proto_binary_fetched_short | 370 |
proto_binary_fetched_bigint | 995 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 686 |
proto_binary_fetched_blob | 356 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 284072 |
