Run Time: 0.000578
Run Time: 0.000194
WHERE (`xf_thread`.`thread_id` = '37016')
Run Time: 0.000697
WHERE (`xf_post`.`thread_id` = 37016) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003538
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (569146, 569187, 739076, 772149, 772186, 791681, 794414))
Run Time: 0.003133
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 8 | Using index condition; Using filesort |
Params: 37016
Run Time: 0.000114
Params: 0, v~
Run Time: 0.000244
Params: v~, XF\Pub\Controller\Thread, Index, valid, thread_id=37016, 1716565574, , 0, v~
Run Time: 0.000166
WHERE (`xf_session_activity`.`user_id` = 15434) AND (`xf_session_activity`.`unique_key` = '15434')
Run Time: 0.000179
WHERE (`xf_thread_reply_ban`.`thread_id` = 37016) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000200
Run Time: 0.000196
bytes_sent | 12400 |
bytes_received | 295330 |
packets_sent | 124 |
packets_received | 1082 |
protocol_overhead_in | 4328 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 222529 |
packets_sent_command | 61 |
packets_received_change_user | 102 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 84 |
rows_buffered_from_client_ps | 84 |
rows_skipped_ps | 84 |
proto_binary_fetched_bit | 613 |
proto_binary_fetched_short | 206 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 612 |
proto_binary_fetched_decimal | 32 |
proto_binary_fetched_json | 507 |
proto_binary_fetched_blob | 209 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 220897 |
