Run Time: 0.000629
Run Time: 0.000239
WHERE (`xf_thread`.`thread_id` = '62')
Run Time: 0.000805
WHERE (`xf_post`.`thread_id` = 62) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001053
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 1 | Using where; Using filesort |
Params: 62
Run Time: 0.000087
Params: 0, 4UL
Run Time: 0.000150
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: 4UL, XF\Pub\Controller\Thread, Index, valid, thread_id=62, 1715330208, , 0, 4UL
Run Time: 0.000094
WHERE (`xf_session_activity`.`user_id` = 2) AND (`xf_session_activity`.`unique_key` = '2')
Run Time: 0.000191
WHERE (`xf_thread_reply_ban`.`thread_id` = 62) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000275
Run Time: 0.000203
bytes_sent | 9813 |
bytes_received | 228269 |
packets_sent | 112 |
packets_received | 865 |
protocol_overhead_in | 3460 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 173531 |
packets_sent_command | 55 |
packets_received_change_user | 77 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 61 |
rows_buffered_from_client_ps | 61 |
rows_skipped_ps | 61 |
proto_binary_fetched_bit | 32 |
proto_binary_fetched_short | 36 |
proto_binary_fetched_int24 | 14 |
proto_binary_fetched_bigint | 103 |
proto_binary_fetched_json | 243 |
proto_binary_fetched_blob | 67 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 172688 |
