Run Time: 0.000383
Run Time: 0.000213
WHERE (`xf_thread`.`thread_id` = '17582')
Run Time: 0.001059
WHERE (`xf_post`.`thread_id` = 17582) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002653
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
Params: 17582
Run Time: 0.000091
Params: 0, ^
Run Time: 0.000156
WHERE (`xf_session_activity`.`user_id` = 9521) AND (`xf_session_activity`.`unique_key` = '9521')
Run Time: 0.000194
WHERE (`xf_thread_reply_ban`.`thread_id` = 17582) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000280
Run Time: 0.000261
bytes_sent | 9434 |
bytes_received | 276955 |
packets_sent | 106 |
packets_received | 862 |
protocol_overhead_in | 3448 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 222496 |
packets_sent_command | 52 |
packets_received_change_user | 86 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 70 |
rows_buffered_from_client_ps | 70 |
rows_skipped_ps | 70 |
proto_binary_fetched_bit | 125 |
proto_binary_fetched_short | 173 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 457 |
proto_binary_fetched_json | 403 |
proto_binary_fetched_blob | 188 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 221146 |
