Run Time: 0.000400
Run Time: 0.000197
WHERE (`xf_thread`.`thread_id` = '29309')
Run Time: 0.000914
WHERE (`xf_post`.`thread_id` = 29309) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005995
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (140806, 141189, 141556, 142130, 142323, 142667, 142986, 143369, 143679, 144150, 144504, 144909, 145304, 145625, 146079, 146539, 147038, 147446))
Run Time: 0.006134
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 18 | Using index condition; Using filesort |
Params: 29309
Run Time: 0.000100
Params: 0,
Run Time: 0.000202
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=29309, 1714281145, , 0,
Run Time: 0.000195
WHERE (`xf_session_activity`.`user_id` = 13861) AND (`xf_session_activity`.`unique_key` = '13861')
Run Time: 0.000199
WHERE (`xf_thread_reply_ban`.`thread_id` = 29309) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000220
Run Time: 0.000224
bytes_sent | 12576 |
bytes_received | 359127 |
packets_sent | 124 |
packets_received | 1102 |
protocol_overhead_in | 4408 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 286326 |
packets_sent_command | 61 |
packets_received_change_user | 122 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 104 |
rows_buffered_from_client_ps | 104 |
rows_skipped_ps | 104 |
proto_binary_fetched_bit | 1323 |
proto_binary_fetched_short | 396 |
proto_binary_fetched_bigint | 1192 |
proto_binary_fetched_decimal | 42 |
proto_binary_fetched_json | 756 |
proto_binary_fetched_blob | 370 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 283830 |
