Lenses
Telephoto
80-200 AF-S ED Focus Problem When Tracking
<blockquote data-quote="Needa" data-source="post: 470872" data-attributes="member: 37799"><p>I would use contact cleaner a small amount on a cloth but I have it readily available. I have used a eraser before though not on a lens. If you go that route be sure not to damage the contacts or get debris on the lens. The normal removal and reinstallation of lenses should keep the contacts clean but it is worth a try.</p></blockquote><p></p>
[QUOTE="Needa, post: 470872, member: 37799"] I would use contact cleaner a small amount on a cloth but I have it readily available. I have used a eraser before though not on a lens. If you go that route be sure not to damage the contacts or get debris on the lens. The normal removal and reinstallation of lenses should keep the contacts clean but it is worth a try. [/QUOTE]
Lenses
Telephoto
